wild water temps
Old 09-29-11, 05:02 AM
wild water temps
i have a 3 yr old bradford white(residential/40 gal) that was faulty when new(replaced entire clip on upper controller),which a yr later has begun to get too hot and trip the reset or run luke warm at best.WHAT THE !@$#@^$@
joel
Old 09-29-11, 06:34 AM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Troubleshoot the lower t stat. Probably your issue.
Should all be under warranty. You just pay labor. Call a Bradford White rep, or get parts from the home store and repair yourself.
Working with electric is dangerous. There is high voltage under thouse panals. Call in a pro if you are unsure.
Mike NJ
