Water heater won't stay lit
Old 10-08-11, 09:28 PM
D
A few days ago we had some bad wind for a few days. The pilot went our a few times... The wind has stopped and I have to keep lighting the pilot. It lights fine and then when I want hot water 5 hours later, it's only warm and the pilot is out. What is going on here?
Old 10-08-11, 10:17 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Hi,
Sounds like a common issue with the new FVIR water heaters.
What is the make and model? Seies # if there is one. Plus if you can post the first 5 digits of the serial # that would be helpful.
Mike NJ
Old 10-09-11, 08:03 AM
D
Hot water heater
It is a Reliance 650XORT (but at the top is says Reliance 606) it has an item id#(instead of serial) 92114---------. Thanks alot man, from one working man to another (I'm a carpenter).
