Aluminum or Magnesium Anode Rod?
Old 12-27-11, 04:47 PM
Hey Guys -
I'm looking at replacing my 12 year old Rheem 50 gallon gas water heater. I don't have any problems with it other than it getting old and a neighbors identical one recently starting to leak, so I figure it's time to replace mine.
My choices for replacement are a Bradford White with a magnesium anode rod or a State with an aluminum anode rod.
They both cost about the same and other than the anode rod, I can't find much difference between them.
I'm on city water and I think our water quality is probably very good.
Is there a reason to prefer one over the other?
Thanks!
Old 12-28-11, 08:28 AM
Received 1,276 Upvotes on 1,215 Posts
Magnesium would be my choice - aluminum is a good choice if you have sulfer bacteria in your water which you should not.
Old 01-01-12, 02:09 PM
A
Received 287 Upvotes on 262 Posts
Magnesium anodes protect the tank a little better. In so doing they may also wear out faster.
Nothing wrong with removing an aluminum anode and substituting a magnesium one, unless you get undesirable odors in the water.
