JHRobin2: Pilot & burner shutting down
Old 06-20-12, 06:42 PM
Same kind of problem with our State Select hot water heater. Model # PR650NBRT, S/N G02338368. Have tried repeatedly lighting the pilot, and I can do that, but after I turn the gas on and set the thermostat and it starts to cycle, it shuts down after about a minute, and when it does, the pilot goes out. There is a clicking sound in the thermostat as it shuts down.
We are renters, so the wife will call the property manager in the morning while I'm at work, but if I could fix it myself easily, I'd do so.
Old 07-19-12, 06:43 AM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Best to let the landlord take care of any issues you may have.
Old 07-24-12, 08:38 PM
Trying2Help's Avatar
Received 11 Upvotes on 8 Posts
So what happened? Having simular problem. I believe it is part of the E.C.O signal, which is a safety "fuse" if the water heater gets to hot. Have to replace the water heater or at least the gas control valve assembly.
Is that what the landlord did?
