Claims that no screws in w/h vent connections after the draft hood.
Old 07-18-12, 08:34 AM
T
Claims that no screws required in Type-B venting, w/h connections after the draft hood connection.
Also claims that metal tape is not favored at connections, by PI's, because it might hide any future corrosion or leaks.
Anyone have any opinions on the above?
Old 07-18-12, 09:24 AM
P
Received 2,326 Upvotes on 2,068 Posts
Claims that B-vent is a snap connection and screws are not required. Also claims to insert the male end into the female end and rotate clockwise until it clicks, indicating that they are locked together. Vertical supports and wall brackets clamp around the outside of the vent but not screwed into the vent.
Old 07-25-12, 10:11 AM
T
Pilot Dane, thank you for your reply.
