Gas Hot Water Tank Settings
Old 10-12-12, 06:22 AM
P
I am trying to determine what the temp settings are on my HWT dial. See image included. What is each bar adjustment 5 or 10 degrees etc. Thanks for any feedback.
Model of Tank: John Wood GSW Superflue
Is the thick vertical red line after the word temp 120 degrees
[ATTACH=CONFIG]4283[/ATTACH]
Old 10-12-12, 07:57 AM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
Probably reasonably close to that.
I doubt there is any 'calibration' of this dial. The markings are more or less 'relative'. You can't really say that each mark is 5 with any kind of certainty.
I'm moving this to the ' Water Heaters ' forum...
Old 10-12-12, 02:18 PM
P
Well i picked up a kitchen cooking thermostat and let the water run for a couple of minutes in a sink closest to the hot water tank and it got up to 138 degrees. Turned it down and will check the new setting tomorrow.
Old 10-14-12, 07:44 AM
NJT's Avatar
NJT
NJT is offline
You got 138 with that setting of the dial shown in the pic? Good garsh, that don't sound right. I would not expect that a setting that low would give that hot... that's dangerous actually, especially if there are young children or seniors in the home.
You might consider installing a thermostatic tempering valve at the hot outlet of the water heater. It's code in many locations now-a-days...
