Water temp,
Old 11-11-12, 02:45 PM
Water temp,
Hello,
I really need some help!! I have my water heater set at 120 degrees which is the lowest hot temperature range. In my shower I turn it all the way to hot and it get decently warm to take a shower, although i would prefer it hotter. However I dont want to turn up the heat on the water heater becase in the kitchen sink the water gets so hot i cant even touch it and it even makes the faucet to hot to touch. What is going on???
Old 11-11-12, 02:50 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
What make shower diverter do you have?
There is a scald control adjustment behind the handle that will most likely need to be changed...
Old 11-12-12, 08:47 AM
what is a shower diverter? and is there a way to lower the kitchen sink temp but increase the shower one???
Old 11-12-12, 09:02 AM
lawrosa's Avatar
Super Moderator
The shower diverter is the valve thats in the wall for the bath.
You will need to remove the handle and adjust the scald control.
The cartridge could be bad also, and thats why I asked toy the brand. It should say it on the handle or face plate.
Old 11-14-12, 05:00 PM
again the shower isnt the problem its the kitchen sink that gets way too hot. I dont want to mess with the shower since its a single faucet.....
Old 11-14-12, 05:04 PM
lawrosa's Avatar
Super Moderator
If the kitchen water is too hot mix it with cold water... Or you need to lower the temp of the water heater if there are scalding conditions.
