Can someone tell me which AO Smith model this ?
Old 02-01-13, 03:52 PM
B
I need to replace this water heater. I can't tell from the images below what model this is. Thanks
https://dl.dropbox.com/u/10499193/1.jpg
https://dl.dropbox.com/u/10499193/2.jpg
Old 02-01-13, 04:44 PM
Received 4,121 Upvotes on 3,701 Posts
A.O. Smith PGHX-40 Series 248
Old 02-01-13, 05:22 PM
B
Do they still sell the same model?
Old 02-01-13, 06:17 PM
I don't think so.
The closest I could find to it is in the following links. Short or tall model.
You may want to check with your local plumbing supply house or where you plan to purchase one from.
There are plumbers on the site that use A.O. Smith water heaters. They may have a better model in mind.
GVRL-40 - AO Smith GVRL-40 - 40 Gallon - 40,000 BTU ProMax Plus High Efficiency Residential Gas Water Heater - Short Model (Nat Gas)
GCV-40 - AO Smith GCV-40 - 40 Gallon ProMax 6 Yr Warranty Residential Gas Water Heater - Tall Model
Old 02-01-13, 07:18 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
That water heater is a 10 year model. Whats the problem with it? Do you want another 10 year model?
