Water Heater leaking
Old 02-05-13, 09:19 AM
N
I just replace the anode to my gas water heater it is 7 years old. I notice the water is leaking around the anode opening. I tightened the anode but the water is still leaking. what are my options
Old 02-05-13, 05:18 PM
F
Received 39 Upvotes on 31 Posts
Did you use a thread sealant on the plug? Teflon tape AND goo?
Old 02-06-13, 11:46 AM
N
Yes I used Teflon Tape, There was a sponge kind of seal around on the opening I had to broke that in order to reach the Hex Bolt. I notice that the water is coming from the surrounding area of the Bolt
Old 02-07-13, 12:24 AM
F
Teflon tape by itself often leaks, I always use a Teflon goo in addition to the tape. Sometimes I simply forego the use of the tape.
