Venting issue?
Venting issue?
Looking at a houw with oil heat - and what I found strange was that the water heater was also oil fired. Apparently the furnace requires a 7" duct up the chimney - and the water heater also requires a 7" duct up the chimney. I am told these should be separate - but the water heater vent goes into the furnace vent - which then goes up the chimney. Is this a problem?
Also posted this in the Oil burner forum - hope that's not an issue - was not sure where best to post it
Why do you ask? Is this your home? It is sized by BTU load from what I know. What size furnace and what size HWH in BTU?
What size is there now?
What is make and model of both appliances?
Who told you this?
Who told you this?
It's a housde my son is looking to buy - the inspector brought up the venting points. Furnace is a Carrier and used to heat a 2500 sq foot house - water heater is 32 gal - but I don;t have the other answers to your questions
