Power vent American WH troubles
Old 02-19-13, 03:42 AM
D
Greetings,
Heater comes on normally, heats water fine (YEA!!!) but won't shut off. Burner goes off but blower does not. Presently the burner comes on again then goes off-this keeps repeating. I turn off the power to the WH and of course the blower stops. Re-apply power and the problem is still there. If I wait an hour or so and turn the power back on, it it back to normal operation.
I'm at the deep end of the pool for me and I would appreciate some helping words.
Cheers
David
Old 02-19-13, 07:08 AM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
How old is the unit? Most have a 6 yr parts warranty and you may be better off paying for labor....
Could be lots of things.... Any codes flashing from the gas valve?
Old 02-19-13, 10:26 AM
D
Ancient!! 19 years so it doesn't owe me a thing. This unit is way before codes etc. The only code I have is "code" water if the burner doesn't light. Ugh...sorry.anyway I'm looking to go tankless but I'd like to get this puppy working until i can choose-ship-install a new unit. Thought there might be a simple fix
Old 02-19-13, 10:48 AM
lawrosa's Avatar
Super Moderator
Could be weak fan not pulling in the pressure switch. Could be the gas valve...especially if its a smart valve. Green light on the side? Igniter/flame sensor???
Your best off replacing it then throw money at it IMO... Tankless? Why? Waste of money IMO although they do have thier place. Large familys or space restrictions.
