a o smith gas water heater not staying lit
Old 08-29-13, 07:29 AM
i am following the instructions to remove the burner to clean the flame sensor. However, i would like to know after I remove the screws on the observation window, do I then unscrew the fitting that holds the burner pipe in the gas regulator switch?
Old 08-31-13, 06:44 PM
P
Temporarily Suspended
Old 09-02-13, 11:51 AM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
You need to state the model and series... You may have a pilot assembly instead of a hot surface igniter....
