Recircirulation pump vs check valve
Old 10-21-13, 06:28 PM
T
I have a 2 year old Grundfos recirc pump on my HWH - and the check valve is at the far end of the system. Is there a test to see which one (pump or valve) is bad if my system isn't operating as it should be?
Old 10-21-13, 06:45 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Yes read page 5 here. The watts and grunfos are the same product with the same type valve.
check valve operation page 5
http://media.wattswater.com/IS-IHWRS.pdf
As far as the pump you should hear it running if its working or feel it for a slight vibration.
Check the timer settings too if you use that feature. Sometimes they get messed up from power outages....
