drain pan - best kind?
Old 10-24-13, 10:36 AM
Hi,
I'm going to have my 15 year old water heater replaced due to rusty water issues (Bradford White 75 gallon in basement). While doing some research I noticed drain pans being installed - I assume this is recommended when installing a new water heater? Is there a preferred drain pan to use?
Thanks!
Old 10-24-13, 10:49 AM
Received 1 Upvote on 1 Post
Aluminum. No rusting, No leaks.
Old 10-24-13, 11:27 AM
P
Received 2,272 Upvotes on 2,024 Posts
Any pan is of limited use unless it's plumbed to a drain and it's also a good idea to have a water sensing alarm. A pan without a drain is a help for a minor leak if you catch it quickly but a decent leak will quickly overflow it.
Aluminum does not rust and is light weight but is can be punctured and it can corrode especially if on a damp concrete. Steel pans are a bit more puncture resistant but can rust especially if their thin layer of galvanizing is scratched. I like plastic pans since they don't corrode or rust but you have to be careful that the feet of the heater don't puncture it.
Old 10-24-13, 12:09 PM
Thank you!
Any specific brand, or should I look for a certain gauge?
Old 10-25-13, 10:36 AM
Any thoughts on Mustee Durapans? The website indicates they are for water heaters as well as washing machines.
This is what I'm leaning towards.
Thanks!
