I have no hot water, Help Please?
Old 12-04-13, 11:49 PM
A
I have a gas hot water heater. This morning I found out that when I turned on the faucet I had cold water; however, as soon as I turned it to the hot side the water just stopped. The pilot light is on... and I am lost. Any help would be greatly appreciated.
Old 12-05-13, 04:36 AM
P
Received 2,270 Upvotes on 2,022 Posts
You have a clog in the plumbing somewhere. Check other faucets around the house. Do they have hot water? It's common for a faucet cartridge to clog or get stuck with sediment. Luckily all you usually have to do is remove the cartridge and clean it out.
Old 12-05-13, 05:14 AM
Received 1 Upvote on 1 Post
Anyone been working on the plumbing and may have left the incoming water line off on the heater?
Old 12-05-13, 06:22 AM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Sound like may be a frozen pipe... Whats the temps been in your area. I hear it is 20 below in some areas of CO.
If so try to get it thawed out before pipes burst, Run a pencil stream of water out the faucets when you do.. Pipes will not freeze then...
