Please review plumbing setup for point of use water heater
Old 12-05-13, 03:16 PM
G
Question Please review plumbing setup for point of use water heater
I finally manned up and took a stab at setting up my Rheem 2.5 gallon heater under my kitchen sink. Couldn't find a lot of info about fittings to use so I may have made some rookie mistakes. On the left is the cold inlet with a 3/8" to 1/2" hose threaded into a 1/2" male to male adapter. I couldn't come up with a cleaner way to accomplish this. On the right is the hot output with the supplied 1/2" to 3/8" adapter and a 3/8" hose leading to the hot side of the faucet. The 3/4" bypass is *now* routed down into the pan via some PVC pipe.
At this point nothing leaks, instant hot water is fantastic, all looks good. Do I have any reason to be concerned about any of these fittings?
Thanks,
Paul
Old 12-05-13, 04:09 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Looks OK..... Please pipe relief valve to the floor.....
Side note..... with the flex lines teflon tape is not needed. There is a rubber seal in the flex lines that make the water tight connection... Tape may actually make it leak....
Old 12-06-13, 04:34 AM
Received 1 Upvote on 1 Post
Loose the tape where the flex lines connect.
I would have used a dielectric nipple on the cold side.
What Is a Dielectric Nipple?
Old 12-06-13, 06:29 AM
lawrosa's Avatar
Super Moderator
Or brass like you have on the hot side.
Old 12-06-13, 11:05 AM
G
Thanks for the input, I'll remove the tape on the threads used with the slip joints. The brass 1/2" nipple is on the cold side, so that has a stainless steel hose attached which also connects to the copper plumbing in the house. Sounds like that isn't a good setup, mixing metals. I like the suggestion above to get a dielectric nipple for the cold inlet, do I need to worry about the stainless line going into the copper plumbing?
Thanks.
