Reset button popped
Reset button popped
5 year old AO Smith electric 50 gallon unit had no hot water today. Removed thermostat cover and found reset button popped. Reset and now working.
What is the most likely cause?
About 3 months ago the water seemed a little hotter than normal but cleared up by the next day
The heater is flushed and T&P valve operated every 6 months.
Thanks in advance
Bart
Thanks in advance
Bart
Haven't touched the thermostat temps in years. I have 3 lovely adult females living with me and the last thing I need is another text claiming no hot water!
You more than likely have a heating element going bad. Usually it's the bottom one. That safety is tripping on water that is too hot. If the problem happens again plan on changing at least the bottom element.
Reset button still has not popped again, but did notice the water wasn't that hot today. Both thermostats are set at 140f. Water temp at kitchen faucet was 115. I just raised them like 2 degrees and they clicked and I heard the upper element start hissing a little. Now the temp is 132. Think I have a faulty stat? I have no problem replacing both stats if that is it.
If you think it is the stat, first make sure the cradle for them holds the stat tight to the tank. I have seen where people have pulled stats and deformed the bracket ears. Just thinkin'
