Help me find a narrow large-capacity electric water heater
Old 01-22-14, 03:47 PM
D
My 40 gallon electric water heater is 10 years old and I think the bottom element is probably bad. I'd like to replace the water heater with a larger capacity one, hopefully in the 65 to 80 gallons range, but the problem is that the hallway closet will only fit one that's 18" (maybe 18.5") in tank diameter. While looking around online I can't find any tank larger than 40 gallons with a claimed 18" or smaller diameter. Can anyone point me in the right direction or tell me there is no hope? Thanks!
Old 01-22-14, 05:12 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Hello and welcome...
I recommend AO smith as a replace,emt... Iuse them and install them...
Unfortunately the best you are doing to get is a 40 gallon in the size you need...
See page 25 here.. ( 18")
http://www.hotwater.com/lit/catalogs/aosrb80000.pdf
The only other option would be a tankless electric... But you would need to run additional circuits to the unit and add breakers to your electric panel...
Here is an example....
Rheem Tankless Electric RTE 27 Series
