Need ideas on replacement Hot Water heater
Old 02-01-14, 07:00 AM
D
Hello,
I'm buying a home next month and it has a gas hot water heater which is over 20 years old. I want to proactively replace it and was thinking of going with a tankless hot water heater to save space.
I'm a licensed electrician so I would be able to install an electric one myself and it doesnt require a vent - which is a plus , however I have a friend who is a licensed HVAC contractor who could install the gas version at a discounted rate.
What should I look for in a tankless water heater and what should I try to steer clear from when shopping for one? I favor reliability over features.
What are the pros and cons of gas vs electric tankless water heaters
Old 02-01-14, 07:53 AM
G
Received 28 Upvotes on 27 Posts
On a Btu basis, natural gas is much cheaper than electricity. The hardest thing about replacing a gas water heater is getting the old one, heavy with lime, out of the basement or wherever. That is a 2-man job.
My guess is that a tankless electric heater will require 240V?
Old 02-01-14, 08:35 AM
Tolyn Ironhand's Avatar
Received 912 Upvotes on 770 Posts
Whole house tankless electric water heater most cases will require 2 x 60 amp 240v feeds (120 amps total)
A gas one will likely require a 3/4" gas line.
Tankless look good on paper, but not so much in the real world. Be sure to do your research before committing.
Old 02-01-14, 01:56 PM
CasualJoe's Avatar
Received 188 Upvotes on 168 Posts
Most people I have talked to who switched to tankless water heaters were not all that happy with them. I'd just replace it with a good brand gas tank type heater, either 40 or 50 gallons, and flush it annually.
Old 02-02-14, 01:21 PM
W
Hard Water
We have very hard water . Do not know about your water chemestry ?
I have been told , with our water , a tankless woll plug ip pretty soon ?
God bless
Wyr
