hot water heater keeps tripping
Old 04-16-14, 05:10 PM
F
Our hot water heater has a little red button that keeps tripping, and we have to reset it, what causes this? The hot water heater is not very old, only maybe 1 -2 years old.
Old 04-16-14, 05:46 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Usually when a t stat goes bad and the heater gets too hot... After you reset it do you notice extremely hot water?
Welcome to the forums....
Old 04-16-14, 07:28 PM
Received 3,991 Upvotes on 3,582 Posts
A defective lower heating element can also cause the overheat problem.
Old 04-17-14, 07:37 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
The little red button is a high temperature limit control and trips when the heater overheats. If it trips frequently, it'll probably need to be replaced once you find and fix the reason for the overheating, they don't withstand the frequent tripping without becoming weak and prone to nuisance tripping.
