water heater placement
Old 06-27-14, 11:45 PM
D
Post water heater placement
putting tee and union on house side of meter running 1/2" off 3/4" pipe to water heater which is about four (4) feet away from gas meter can anyone forsee any problems with that or should I take a different way in doing this.....comments please
Old 06-28-14, 07:17 AM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Welcome to the forums. Use 3/4" for the entire trunk run and only use 1/2" for the turn ups to the appliances services. The important thing is placing the water for the shortest run to your appliances. If needed, centrally locate the water heater. Gas lines can be extended.
