Water heater flushing: To Flush or Not To Flush
Old 07-31-14, 07:12 AM
Question Water heater flushing: To Flush or Not To Flush
...That is the question
I bought my house last year, and it has a relatively new gas water heater (2008?)
No idea if its ever been flushed...
Is there consensus on whether to leave it alone or go ahead and flush it?
Old 07-31-14, 07:15 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Not a plumber but I flush my electric heater(s) at least once a year. If I don't my 60 gallon hot tub gets sand like stuff in it.
Old 08-01-14, 06:18 AM
my cocern is not knowing whether its ever been flushed--i read somewhere that u could have trouble closing the drain, if sediment gets stuck there
Old 08-05-14, 05:40 PM
A
Received 287 Upvotes on 262 Posts
Get a screw on garden hose cap. Have it ready when you drain the water heeater and be prepared to screw it on the water heater drain spout if you can't shut it off completely.
The cap can be purchased separately or you can borrow one from a daisy chainable lawn sprinkler.
Old 08-05-14, 06:22 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
6 yr old heater I say leave it... Let it run its course....
Whats make and model???
Old 08-09-14, 09:56 AM
sorry it took so long to reply! Its an AO Smith 40 gallon gas water heater, model GCV 40 200
build date in 2008
Old 08-09-14, 10:09 AM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Gas WH's are not as big a problem as electric, where buildup on the elements can cause burnout and poor performance. Are you on city water? Any idea of the hardness of your supply?
Old 08-09-14, 12:32 PM
city water. But I just had a water softener put in as the water was way too hard for us when we moved in last fall
