Question - on theory.
Old 08-18-14, 12:44 PM
T
Received 4 Upvotes on 4 Posts
I purchased and installed a Rheem XG40T09HE40U0 hot water heater today. It went in and fired up without issues so far.
My question is how the Control Valve gets its power. There it a single LED that flashes one time when its working, (and it does) and is supposed to flash multiple times for a fault, so there must be some type of logic in there.
There is a link to the instruction manual if interested.
Rheem Performance Plus 40 gal. Tall 9 Year 40,000 BTU High Efficiency Natural Gas Water Heater-XG40T09HE40U0 at The Home Depot
I'm hoping there is not a battery involved...
Old 08-18-14, 01:02 PM
F
Received 39 Upvotes on 31 Posts
Rather than having a simple thermocouple that generates only enough power to hold open the gas safety valve the new water heaters use a control that has a thermopile (that may be Honeywell brand name) and the thermopile generates about 750 millivolts (about 3/4 of a volt) and that is sufficient to operate the gas valve and the diagnostic electronics. As far as I know there is no battery involved but I have not taken mine apart to check.
Also, using the thermopile control allows for using an electric thermostat instead of the mechanical thermostat of the older controls. This allows for a closer temperature differential between the firing and not firing temperature of the water.
Old 08-18-14, 01:03 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Its powered but the t couple... I assume if the pilot went out the light is powered by a slow discharging capacitor on the PCB...( capacitor charged buy the pilot/t couple)
Old 08-18-14, 02:06 PM
T
Thanks to both of you for this -
