Water heater turning off
Old 09-11-14, 07:27 PM
D
Hi,
Our gas water heater started to turn itself off after running 10min or so after lighting up. If I light up again immediately after turning off then it runs even shorter around couple of minutes then turns itself off again. I recorded its turning off in the below video (it turns off around 55th second)
Water heater turning off - YouTube
Any help appreciated about the possible reason of the turning off.
Also looking at the flames and the small embers on tehe interior walls normal ?
Thanks.
Old 09-12-14, 04:54 AM
Received 4,105 Upvotes on 3,687 Posts
Welcome to the forums.
I'm not the pro here but the make, model and serial number of your water heater would be extremely helpful.
Old 09-12-14, 05:11 AM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Its starving for air and the thermal switch is tripping..
Yes make and model please.. Series # if you can find it...
Oh, welcome to the forums...
Old 09-12-14, 08:46 AM
D
Thnaks for the replies, My water heater is :
Kenmoore , Power miser 6
I believe it is more than 10 years old. I will clean the bottom and see if it helps.
