What makes my water get COLD for few min and back hot?
Old 11-20-14, 02:08 PM
F
I just put this 50 gal water heater in a month ago.. Now taking a shower
hot water fine after 5 min it gets cold for a few min then back Hot rest of the time..
wife been telling me that last week.. I said naw woman I just put in a new $300 one. and was not doing that to me on my showers till TODAY.. So I had to EAT CROW hearing her yapping at me
Now I did burn out a top element when I put it in.. Thought was full but was not.
I had a extra hanging up checked it and it showed working.. I put it in water got HOT thought ok good to go..
how i fig that one out...
Old 11-21-14, 06:38 AM
Received 1 Upvote on 1 Post
Is it just the shower acting up?
Check it at a faucet, if it's ok there then it's the anti scald inside the control valve.
Very common to get trash in it if you did not remove the aerator on a faucet and flush out the lines before using the faucet.
Any major plumbing repairs like that stir it trash in the lines.
Old 11-21-14, 08:00 AM
F
One fellow told me try another shower see if it does it there..
he said might be the faucet.. how do you fix a faucet? You got to replace it??
where is the control valve?
Old 11-21-14, 09:14 AM
P
Received 2,230 Upvotes on 1,989 Posts
The anti scald valve is located inside some newer faucets. Some faucets have a balancing valve that prevents scalding. Both are a cartridge inside the faucet and are removable and replaceable from the front, knob side so you don't have to replace the entire faucet. The first thing to do is check other fixtures around the house to narrow it down to a water heater, plumbing or fixture problem.
Old 11-21-14, 04:49 PM
F
lord id never find that.. i will check a you tube Im not the sharpest knife in the drawer on fixing things. i mostly break things
Old 11-21-14, 05:42 PM
Norm201's Avatar
Received 727 Upvotes on 643 Posts
I gotta admire a guy who knows his limits and admits it.
Old 11-21-14, 06:34 PM
F
This might be it now I see a video on how to fix something I will do it..
spoon feed me I can do it.
https://www.youtube.com/watch?v=6CiU_3Q-yVY
Old 11-22-14, 03:41 AM
Norm201's Avatar
Great find. You're on your way to be a DIY'er
Old 11-22-14, 10:44 AM
F
Guys I go to my local supply place tell him what I want he bings me the white
piece that goes into the 2 round hole as in the video.. I told him what I was looking for.. He went and got a Delta facuet box for a shower.. There was no piece in the box like the man took apart with the 2 round hoes.
He got the big brass piece that it goes into. It sure dont look like what the man took apart....
white long thing cost me 45 dollars use it IT dont work I lose it
house is 20 years old. That part said pre 2005..
what ya think on this ??
Old 11-22-14, 10:58 AM
czizzi's Avatar
The last two pictures are of a Delta shower rough in and cartridge. Not the same brand as in the YouTube video attached to a previous post. Which is the unit that you have? If it is the delta, then the cartridge is all that needs to be replaced. They have several series of cartridges, you may have pull yours to figure out which you have.
Old 11-22-14, 11:42 AM
G
Received 2 Upvotes on 2 Posts
When you open up your valve to get to the module, be careful NOT to use too much strong arm torque on it. The older Delta bodies have several soldered pieces in the back. If they get twisted, they can pull apart and you will have to remove the old body and solder on a new one. Not really an amateur job. Don't ask me how I know.
Old 11-22-14, 12:34 PM
F
It is a Delta I will take it apart tonight to see what it looks like..
Tks for a all the input on this job...
I know I ought to call a plumber, but I like trying it
Old 11-22-14, 12:44 PM
czizzi's Avatar
If the rough in matches that of the pictures, then google delta cartidges to find your match. It is either a 13, 14 of 17 series. Plumbing houses will have the replacements, I am not sure if box stores carry in stock or not. OTOH, if you remove and find an o-ring that is visibly damaged, torn or otherwise worn, you may be able to repair with a simple o-ring replacement.
