Draining HWH
Old 02-07-15, 04:14 PM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Draining HWH
Hi All, what harm would it do to a electric WH to drain it for the months my condo if vacant ? I can see no harm.
Thoughts
Geo
Old 02-07-15, 04:26 PM
F
Received 39 Upvotes on 31 Posts
Just make certain you turn off the power BEFORE draining and also make sure the entire tank is filled (continuous flow from a hot water tap) BEFORE turning the power back on. Hang a tag on the circuit breaker or local disconnect advising of the condition so no one else will turn on the power.
Old 02-07-15, 05:37 PM
Received 1 Upvote on 1 Post
Heat still going to be one to prevent the pipes from freezing?
No reason to drain it if the heats going to be above freezing.
Old 02-08-15, 04:36 AM
Geochurchi's Avatar
Sorry,I should have mentioned the condo is in Fla. In a second floor unit,just want to be safe while I am not here,got away from the cold for the winter.
Geo
