Old water heater leaking
Old 02-20-15, 02:04 PM
K
hello, my 20yr.old water is starting to leak from the bottom.i have tankless boiler which makes the hot water.i haven't powered the water heater since the new boiler went in{8yrs]. just storage.what I want to do [till spring]is. by pass the water heater w/ss flex {watts].the water heater is plumbed w/copper flex.which i'll unhook and make the by-pass. any thoughts apprecieated
Old 02-20-15, 07:19 PM
CasualJoe's Avatar
Received 188 Upvotes on 168 Posts
Any time a boiler is mentioned in reference to making domestic hot water my thoughts always go to a separate stand alone tank type water heater. I think it would be much more economical to operate in the warmer months.
Old 02-20-15, 08:00 PM
Received 1 Upvote on 1 Post
So you have a leaking water heater that's 5 years past the expected life and still want to use it. Hmm.
So what's the question? Where to take it to dispose of it?
Old 02-20-15, 08:44 PM
Received 4,119 Upvotes on 3,699 Posts
You can certainly bypass the hot water heater but in losing that as a storage tank you may not have much reserve hot water as the tankless coils don't deliver much heated water on demand.
Old 02-21-15, 12:31 PM
K
thanks for the replies.i'll get rid of it and probably replace it.for now while it's so cold,i want to bypass it without upsetting anything else.loc
