top vs bottom inlet
Old 03-01-15, 03:53 PM
Q
Received 1 Upvote on 1 Post
top vs bottom inlet
All the sales material says a bottom inlet water heater saves money. But I thought a top inlet transfers the cold to the bottom through a dip pipe anyway.
So, what's the difference?
Secondly, I know you can't connect pex to the top but can you connect it directly to a bottom inlet?
Old 03-01-15, 03:59 PM
F
Received 39 Upvotes on 31 Posts
Pure advertising hokum, nothing more, nothing less.
Old 03-01-15, 06:36 PM
CasualJoe's Avatar
Received 188 Upvotes on 168 Posts
I think Furd is right.
I am more of a copper pipe guy, but from what I have read you are right, you shouldn't run pex pipe to the top of a water heater. That being said, I have seen gas water heaters with pex pipe run right to the top connections of the heater.
Old 03-01-15, 07:56 PM
Q
Can you run pex into the bottom directly... For a bottom inlet
Old 03-02-15, 08:52 AM
CasualJoe's Avatar
I cannot think of a single reason why not. The only bottom feed water heaters I have seen were for mobile homes, but I cannot say there may not be some others out there.
