Connecting water heater with pex
Old 03-02-15, 04:07 PM
Q
Received 1 Upvote on 1 Post
This ok for pex pipe?
View image: IMG 20150302 185943451
Old 03-02-15, 04:12 PM
Received 3,417 Upvotes on 3,064 Posts
That short white piping off of the T & P valve needs to be copper and go down almost to the floor.
Is that a BX connector on your NM cable there ?
I don't see a problem with the pex but I'm sure others will chime in.
Old 03-02-15, 04:17 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Code changed AFAIK... Plastic piping is allowed for the relief valve now.. Some time ago..
Connections to the heater is supposed to have a ninimum of 18" copper I believe before any transition to pex...
Old 03-02-15, 04:39 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I use these. They seem to clear the body and have a metal attachment point that can be removed.
Camco Polypropylene Runoff Top-Mount Water Heater Drain Tube - 60 in.-10962 - The Home Depot
Old 03-02-15, 05:32 PM
Q
The pex here is the cold water pipe to a bottom inlet.
Just worried if it needs support and whether it's too close to heat from top of heater?
What's a bx connector? The one I have is a plastic one.
Old 03-05-15, 02:25 PM
Q
Does pex need supporting horizontally where it comes from the shark bite connector?
And is it OK across the top of tank like that?
Old 03-05-15, 03:43 PM
chandler's Avatar
Without a doubt support any pipe to where it is straight into a pex or sharkbite fitting. Pex is OK across the tank, just not pretty The electrical connector you have going into the water heater pecker head does not have a strain relief on it, and is made for BX. Yours should look like this, or metal with screw strain reliefs.
Old 03-05-15, 08:47 PM
Q
What's the best way to support the pipe?
And what's a strain? Why is the plastic for the nmd cable bad?
Old 03-06-15, 02:47 AM
chandler's Avatar
Attach a block of wood to your stair riser and use a clamp to hold the pex in the proper position. As far as the strain relief, you are missing a collar and possibly an insert to make the connection solid. You don't have anything that will keep a good sharp tug from disconnecting the wires inside. Here are your strain relief with the cap applied and a screw type strain relief.
Name:  nm strain.jpeg
Name:  nm strain2.jpg
Old 03-06-15, 06:59 AM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
The power wiring to the heater from the above joists really should be in conduit. I'd use 3/4" steel flexible metal conduit.
