water heater 98i drain install help please
Old 04-07-15, 03:09 PM
H
Question water heater 98i drain install help please
Hi,
I am having issues figuring out what to do with the drain plugs on this Rinnai 98i, there is nothing in the book and they don't like helping the home-owners when I called. please help...
following is the picture of the diagram... and there is nothing in the book about this.
Old 04-07-15, 09:10 PM
Received 4,082 Upvotes on 3,665 Posts
I didn't see that exact model number in the heater list.
Plugs in question ? What are you trying to do to them ?
Old 04-07-15, 10:53 PM
F
Received 39 Upvotes on 31 Posts
What is your concern? The plugs are removed to prevent freezing when the heater is laid up. They are of no consequence during normal operation. If you are planning on laying up the house during the winter and traveling to a warmer climate then you could install valves instead of the plugs to make it slightly easier to drain.
Old 04-08-15, 02:16 AM
H
I don't know what to do with them like just leave them be or actually hook it to the drains directly.
full model number is : Rinnai RU98i
and it only has 2 extra plugs not 4... sorry
Old 04-08-15, 03:42 AM
F
If they are metal plugs then leave them be. If they are plastic plugs then replace them with metal using Teflon pipe paste on the threads.
Old 04-08-15, 03:49 AM
H
They are plastic plugs hand tighten on there.
