Intermittent Rattling
Old 07-05-15, 04:44 AM
G
Once in a while (1/week, 1/month, random) my water heater will make a horrible/loud rattling sound during the middle of the night for about 10 seconds. It's enough to wake us up and scare the crap out of you.
I guess it's possible that it's my furnace instead, but it started after installing a new water heater.
If my heater needs to be flushed, would it behave this way or would it be noisy on a consistent basis?
Old 07-05-15, 07:39 AM
P
Temporarily Suspended
Can you tell us the make & model, of it? Isn't the furnace off, this time of year in Arizona? Is the water supply from the municipality or a well? Drain a little water from it to see if it's discolored.
Old 07-05-15, 09:18 AM
Received 852 Upvotes on 747 Posts
My water heater regularly makes an intermittent popping or cracking sound but I've always thought it was just expansion/contraction. How far is the water heater from your bed room?
btw - welcome to the forums Gordon!
Old 07-05-15, 06:43 PM
CasualJoe's Avatar
Received 188 Upvotes on 168 Posts
A new water heater shouldn't need to be flushed.
Old 07-05-15, 06:47 PM
G
BTW: It's from Bradford White, model # M45036FBN. 50 gal, natural gas.
I ran the drain just a little bit and the water was clear. The water source is from the town (not well).
Thanks
Old 07-06-15, 05:05 AM
P
Does the tank set on a base or directly on the floor? Can you rock it by hand?
Old 07-06-15, 08:03 AM
michaelshortt's Avatar
Could it be the relief valve lifting? Check were the relief valve drain piping ends for dampness.
