GE WH: Bad Igniter
Old 12-25-15, 12:35 PM
ray2047's Avatar
GE WH: Bad Igniter
A friend has a 40 gallon GE water heater (I don't know the model#) that is perhaps 10 years old. The tech that came out to check it because no hot water said it was a bad igniter. He said it wasn't worth fixing.
My questions are:
Do you agree with the tech?
What is the average cost for an igniter?
How hard are they to replace.
Old 12-25-15, 01:35 PM
Received 4,138 Upvotes on 3,716 Posts
A HSI (hot surface igniter) can run $35-75.
Pull the igniter out and test it. If it's bad it's a judgement call to replace.
Me.... I'd replace it.
Old 12-25-15, 03:45 PM
ray2047's Avatar
So basically will a Rheem HSI work? I am not having much luck Googling GE igniters. This wouldn't by any chance be a more or less universal part would it?
Old 12-26-15, 06:27 AM
Tolyn Ironhand's Avatar
Received 912 Upvotes on 770 Posts
Come on Ray, how about a model number!
IMO I would also fix it, but I would fix it myself.
Old 12-27-15, 07:27 PM
CasualJoe's Avatar
Received 188 Upvotes on 168 Posts
A Rheem ignitor will probably work, but I'd get the model number and look it up that way first. Once you confirm that it is the same as a Rheem part, you may find some other after market manufacturer that also makes a replacement part.
