A O Smith
Old 01-31-16, 12:26 PM
A O Smith
Renter's broke out the little window that you can see the flame on the water heater? Model # gvr 40 100 is there a replace part? I don't know what that part is called.
Old 01-31-16, 01:09 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Call AO smith for the actual part #..
They do have them..
Example here, but this may or may not be the part # for you..
9003379005 - AO Smith 9003379005 - Natural Gas Burner Assembly
AO smith support..
Customer Support | A. O. Smith Water Heaters
Also my advice since thats an old seies 100 with the troublesome corderite disk issue, I would probably just go ahead and replace the water heater..
The window may have been broken to get more combustion air to the unit.. So if you do put a new door on the heater may not work...
