Tankless Water Heater Question
Received 0 Votes
I wanted to spec out a tankless water heater to replace a residential unit to cover a shower/tub, dishwasher, and two bathroom sinks.
What would be an appropriate tankless water heater, hooked up to natural gas, for 8-9 gallons per minute. The part that is confusing me is getting a unit that can heat up the groundwater for a winter in Pennsylvania.
Any recommendations on a brand + model number?
Thanks in advance!
Thanks in advance!
Why do you want tankless?
Average ground water temp is 54f in our parts.. Do the math on the units with temp rise, temp you want the water, and GPM you want...
Plus a unit that size a dedicated gas line is needed as these units are 200k btu or more...
Plus youll get a H/C sandwich effect most likely and may not be happy...
IMO stick with a tank...( Unless there is a valid reason tankless is what you need)
Tankless heaters sound great until you start looking at actually installing one correctly. I'd go with a unit with a tank as well.
Received 0 Votes
Don't need
You don't need a dedicated gas line and there is no cold water sandwich. That is if you know what you are doing. Contact someone who is experienced and trained in tankless water heaters. Dedicated gas lines and cold water sandwhich went out over six years ago.
( Note I am a plumber 30 years)
