Cold water supply pipe is hot
Old 08-27-16, 12:43 PM
P
Received 2 Votes on 2 Posts
So I was visiting my friend at his new place and was surprised to feel that his cold water supply to 50Gallon water tank was really hot for about 10-12 inches.
My water heater cold supply is actually cold all the way into the connection.
We checked it few times....even after no hot water was run and the burner wasn't on for a while.
What is causing so much hot water back up in his case ?
Old 08-27-16, 02:02 PM
P
Received 969 Votes on 890 Posts
Maybe the check valve on the water heater inlet fell out or is not working.
Old 08-29-16, 05:21 AM
P
is the check valve integral to the water heater ?
I don't recall seeing a check valve installed on any pipes going to the water heater....just a standard 3/4 inch shut off valve.
Old 08-29-16, 09:31 AM
P
Normally they come already installed in water heater but they are a plastic/rubber thingy pushed into the inlet. It may be damaged, fallen out or someone may have picked it out when installing the unit. I had a helper once stick a screwdriver in to pull it out because he didn't know what it was. Crazy stuff can happen.
