replacing anode rod info
Old 01-05-17, 08:31 AM
My water heater is about 7 years old and I didn't realize I should be performing maintenance on it. It works fine so I just need to perform some maintenance. I plan to replace the anode rod and have some questions. The manual for my water heater is http://www.statewaterheaters.com/lit...184165-003.pdf
1) What size replacement should I buy? I'd rather not take it out and the order it. I want to have everything ready to do this all in one shot.
2) Is there a secondary anode and should I replace that as well.
3) Should I buy the magnesium or aluminum?
4) should i buy the flexible? I believe I have clearance, but if the cost difference is a few dollars I don't mind.
5) I need to turn off the gas correct?
6) Do I need to turn off the water heater itself? How do I do that? Turning the knob to off or pilot?
6) I need to shutoff the incoming cold water correct?
7) I should drain a few galons of water first correct? I plan to attach a hose and drain enough so that the water is clear. But the water would be burning and I should be careful correct? OR should I wait some time for the water temp to go down?
8) any other advice?
Old 01-05-17, 08:56 AM
Norm201's Avatar
Received 356 Votes on 321 Posts
My opinion only. If it's working, leave well enough alone. The average life of a HW tank is about 10 to 12 years. You have 7. Consider a new tank in about 3 to 4 years. Unless you have exceptional hard water problems, HW maintaining is overrated. Especially if you have those plastic drain valves. Very often once opened they never properly seal again
Old 01-06-17, 12:36 PM
thanks for the warning.
After some thought I decided that I'm going to just drain a few gallons now to get rid of any sediment. I'll hold off in replacing the anode rod until summer, in case there are any issues.
