On demand gas water heaters
Received 0 Votes
If you have an on demand propane heater like the EcoTemp and you put in a small solar pre heat water tank before the heater....will the unit adjust the fire based on the incoming water temp??
You'd have to check the manufacturers specs on the maximum allowable incoming water temperature but the heater should fire/adjust based on outgoing temperature.
