Floor drain size for overflow and pan?
Old 10-11-17, 10:44 AM
Q
Received 1 Vote on 1 Post
As I understand it you can't plumb the floor pan or pressure relief pipe directly into plumbing.
If I install a floor drain, what size pipe should it be?
I tested a pressure relief valve, it doesn't seem like a 1.5" waste pipe would handle the flow to prevent a flood?
Old 10-12-17, 09:15 PM
Q
Putting a floor drain in seems difficult when there isn't one there already. Would have to rip up the floorboards?
Old 10-13-17, 12:56 AM
Q
The water heater will be in a closet about 10ft away from the outside of building so it's also difficult to install a pipe to outside. Can it be tied into a roof drain/downspout?
Old 10-13-17, 06:33 AM
Received 108 Votes on 95 Posts
What's under that closet, crawl space, basement, first floor rooms?
Any drain pan I've used has a 1" drain.
Old 10-13-17, 02:09 PM
Q
Another closet on floor below and below that another closet and below that the basement crawl space. I could connect a flexible 1" pipe and run it down to the basement sump pump but it's a long way down.
does 1" vinyl tubing exist or is 1" pvc best?
