Are these dents aesthetic or might be worth replacing
Old 04-17-18, 05:49 PM
R
I've attached an image of all the imperfection of a new water heater I just purchased. The box was intact but when we opened it up it had all these imperfections. Thing is it we brought it from a store located 1 hour away so is this worth making the commute back to have it replaced?
Old 04-17-18, 05:59 PM
Norm201's Avatar
Received 729 Upvotes on 644 Posts
most likely not a problem. I've installed tanks that were dropped on stair edges as they were being taken into the basement and they worked fine. As long as the control valve was not hit. However I would return the unit for a new non-dented unit. Why would you want a brand new dented water tank? Maybe they will give you a price break if you're willing to keep it.
Old 04-17-18, 06:25 PM
R
If I keep it they'll refund 10% of the total cost...So about 100$.
Old 04-18-18, 06:42 AM
P
Received 2,328 Upvotes on 2,070 Posts
I would not replace it. There is several inches of insulation between the thin outer skin and the water tank inside. Unless the fittings got bumped the dents are mainly cosmetic.
