Go Back  DoItYourself.com Community Forums > Plumbing, Piping, Water Heating, Wells, Air & Water Filtration and Conditioning > Water Heaters
Reload this Page >
old water heater 20 diameter. new - 21. Will this affect the water line spacing?
Old 11-21-18, 11:24 AM
L
I'm looking for a direct replacement for my gcv 50 300 water heater which has 20 inch diameter. If the replacement has 21 inch diameter will that affect the spacing of the water lines? I'm trying to avoid replacing my water lines. Thanks
Old 11-21-18, 12:08 PM
Received 3,950 Upvotes on 3,543 Posts
I'm not a plumber but I've replaced maybe 30 or so water heaters. The hot and cold fittings never line up. I carry extra fittings and add them as needed. Even the gas valves are in slightly different locations.
I'm not sure you'll find an "exact" drop in replacement. I haven't.
Old 11-21-18, 01:20 PM
ray2047's Avatar
Why I always use flex lines.
