Elec HWH Heater Replace & Install
Old 01-26-19, 08:15 AM
I
Hello,
I have a question about an older electric HWH that I am going to replace. FYI it's currently not up to code because it does not have an expansion tank. I plan to install one when I pull the old tank out. However, I am not sure about a particular valve that is upstream of the cold water shut off. It looks like an air vent valve but I haven't come across anything online that is similar. See below:
1) what is this valve on the cold water inlet to the HWH?
2) is this valve necessary when I plan to install an expansion tank with the new HWH (can I remove this valve)?
3) does anyone recommend against using properly rated shark bite quick connect hoses for the hot and cold water lines and the T&P relief valve? The T&P relief valve comes with the tank on the side pointed down. I am considering using a shark bite male adapter (rated 200'F) to connect to the T&P relief valve and attach a copper tube to discharge to the ground (6" above according to code). So I basically plan to do no soldering for any connections to the HWH.
thanks for any input
Old 01-26-19, 12:05 PM
Received 1,044 Votes on 968 Posts
Welcome to the forums.
I'm not the pro here...... just checking in. I was looking at Beacon valves and the only thing I found that looked close was a tempering valve but that would require a connection to three pipes. Are there three pipes connected to that valve ?
Old 01-26-19, 12:35 PM
I
No there there are no other pipes tied into this valve. It's in line with the cold water shutoff.
Old 01-29-19, 08:53 AM
I
If no one else has one of those valves I suppose there wouldn't be any harm in removing it?
Old 02-09-19, 01:09 PM
Received 1 Vote on 1 Post
Pressure reduction valve.
Looks like that to me. And likely should be replaced. Shark bites are OK but could get pricey if you need a lot of them. But, still much cheaper than most plumbers would charge. Don't forget to plan on a new expansion tank, even if you don't have one now.
Old 03-21-19, 04:10 PM
R
More
I would remove the prv or whatever it is-most likely not working anyway. Shark bites ok. Keep them away from vent pipes - O-rings will fail from heat. TPR tubes can be purchased premade cheaper than the sharkbite fitting. Six inches or less off floor is usual spec.
