Impending Tank Leak?
Old 06-16-19, 04:42 PM
Gen
Gen is offline
At one of my units, See attached pic of water heater top couplings--really corroded and almost seems to be disintegrating.
Can they be replaced/repaired? Will this leak soon? Or do I need a new tank? Thanks!
Old 06-16-19, 11:19 PM
What is the age of the water heater ?
Beyond a certain age it becomes more cost effective to replace the tank then service it.
That looks like a badly corroded fitting. There may be a dielectric problem there using the wrong fitting. The fitting in the tank may also be corroded not allowing the fitting to be replaced.
Old 06-17-19, 04:54 AM
How old is the heater? If it's over 10 I wouldn't try replacing the union and would just plan for the eventual replacement. If it's less than 5 years old I might try replacing the pipe nipple and union. I would also inspect the anode and see if it needs replacing. Yes, there is an odd period between 5-10 years where you'll have to decide which way you want to go.
