Bradford White pressure switch
Old 06-21-19, 12:27 PM
I have a Bradford White HW heater. I got an error code that the pressure switch was bad. Had a plumber out and he confirmed. So I got the new switch put it in and it still is giving me the same error code. Ive done everything in the manual to diagnose, but the switch is brand new. Any suggestions?
Old 06-22-19, 10:31 AM
CasualJoe's Avatar
Old 06-22-19, 04:39 PM
Welcome to the forums.
Are you sure the code was the pressure switch was bad ?
Or was it........ the pressure switch is not closing ?
Pressure switches rarely go bad. The only way to diagnose a problem with the pressure switch is to use a manometer to measure available vacuum. Your problem is more likely an exhaust problem or possible clogged port on the draft inducer.
