Are Braided Water Lines Safe & Up To City Code?
Old 08-15-19, 07:52 AM
Received 1 Vote on 1 Post
I am gonna be replacing the water heater. I had installed new water lines this past May but the braided type. A plumber suggested these are
1-not up to city code and
2-usually never last but a year and should be replaced thereabout.
Location is Balch Springs just outside of Dallas Texas. I don't mind to replace them as they are not a costly item but now I can't help but to want to know for sure for myself. So can some one chime in on these 2 suggestions?
Old 08-15-19, 08:15 AM
Received 15 Votes on 15 Posts
From what I heard, braided water connectors such as these are generally legal (some cities have different regulations) and can be expected to last for five years.
They are technically hoses. The braid prevents bursting with a massive leak but the rubber or vinyl hose inside can still eventually biodegrade and crack and leak slowly.
bambata voted this post useful.
Old 08-15-19, 09:50 AM
Thanx!
So it's ok to assume that about the same duration applies for the braided water lines to sinks and toilets cisterns?
Old 08-15-19, 09:58 AM
XSleeper's Avatar
Received 194 Votes on 180 Posts
You don't use them in inaccessible areas (like within a wall). Other than that there's nothing wrong with them. They don't just fail after any certain amount of time but many times they are no longer reusable once they get old. They are more likely to leak if reused, especially if they are kinked at a sharp angle.
Old 08-15-19, 10:40 AM
Received 120 Votes on 107 Posts
That's what I put on my water heater when I installed it around 8 yrs ago. Haven't had any issues.
