nipple threads
Old 11-11-19, 10:38 AM
nipple threads
I measured the od threads on the hot water tank out nipple ,Lochnvar 2001, they measured 1.05 inch which I assume is 1 inch OD.. Is that right??? So a premade pex hose fiting would have to be 1 inch also or get a 1 inch to 3/4 inch adaptor and get a 3/4 inch pex hose fitting...yes??
Old 11-11-19, 11:06 AM
Received 64 Votes on 59 Posts
Pipe is measured on the inside, and it can vary by wall thickness, almost never dead on, but 1.05 happens to be the O.O. of 3/4" pipe so sounds like that's what you have.
Old 11-11-19, 11:12 AM
Received 142 Votes on 127 Posts
If I remember correctly the few water heaters I've worked on all had 3/4" on both the inlet and outlet.
