rheem 8k tankless water heater
new unit new,40amp breaker, new 8/2 with ground wire. LED
control panel does not light up, and no hot water. . I have power to the unit and thru it with or without the water on. this is the second one and the same problem. Any suggestions would be appreciated. thanks
Have you tested the power at the water heater and confirmed you have 240v between the two hots?
That is your next step.
You've confirmed 240v at the unit so the supply is correct.
That only leaves the pressure/water flow sensor as a problem or water flow to low to turn unit on.
Diagnostics are on page 9 but there isn't much to check.
Rheem installation manual
