Propane water heater
Old 02-26-20, 12:01 PM
Z
Do propane hot water tank (not tankless) heaters need a drain for condensate? Im looking to avoid installing a pump. No floor drains available.
ive heard condensate for gas fired appliances is acidic. Is draining to a municipal sewer allowed in Ontario? Seems like it’s not allowed in some areas due to the acidity and that it could damage drain lines.
Old 02-26-20, 02:01 PM
P
Received 2,263 Upvotes on 2,016 Posts
That depends on the type. Traditional heaters that have a standing pilot and NO exhaust blower do not have a condensate drain and do not need a pump.
Old 02-26-20, 02:13 PM
Z
I assume that type then would require a chimney to vent?
Old 02-26-20, 08:16 PM
Received 4,093 Upvotes on 3,676 Posts
Yes...... that is a correct assumption.
Old 02-27-20, 04:44 AM
P
Most high efficiency water heaters with a powered exhaust vent fan can use PVC for their exhaust and this exhaust can be run horizontally which can make the chimney/flue/exhaust easier to run. But, these types of heaters may produce condensate and have a drain. To be certain look at the specs and installation instructions for the heater you are considering.
Old 03-01-20, 04:15 PM
CasualJoe's Avatar
Received 188 Upvotes on 168 Posts
What is your plan in the event the Temperature and Pressure Relief valve should open and discharge water to the floor?
Old 03-01-20, 05:04 PM
Z
We have an existing electric hot water tank. The plan has been “cross your fingers”.
