Why Resistorized Water Heater Anode?
The anode rode is sometimes called a sacrificial anode because it sacrifices itself (dissolves away) to retard corrosion of the tank.
The most detailed description of the resistorized anode is that a resistor (in the screw in cap at the end of the rod) prolongs the life of the anode.
Doesn't that mean the tank will suffer a little bit more corrosion compared with having a non-resistorized rod (although there is still some protection offered by the resistorrized rod)?
Yes, I think your thinking is correct. I have never seen a resistorized anode and I know on boats you want the best electrical contact you can get. Resistance is to be avoided.
