aqua plus series 2 wiring
Old 04-24-20, 11:16 AM
N
Iím replacing my old KERR indirect water heater with a new Weil McLain aqua plus series 2.
My question is ..... the old tank has a two wire non powered aquastat. The Weil McLain has a 24v powered digital stat. Where would I get the 24 volt power from.
The boiler is controlled by a Tekmar 260 and a taco 4 zone relay switch.
Thanks, Dan
Old 04-24-20, 11:54 AM
Received 4,090 Upvotes on 3,673 Posts
Welcome to the forums.
We like to keep all posts on a single topic in the same thread. This is your thread.
Give me a closeup shot of that zoning panel. We should be able to get 24v from there.
See if there is a terminal strip like in the picture....
Old 04-24-20, 01:52 PM
N
Thanks Pete..
So I can just hook the wires to this ?
Old 04-24-20, 07:03 PM
Yes.... that is a source of 24vAC.
The current requirement of the new thermostat is very low so it won't be overloaded.
Old 04-25-20, 04:21 AM
N
Thanks so much!!
cheers
