No hot water
Old 08-02-20, 12:02 PM
1
No hot water
Turn off electric and checked heater to make sure. Both elements unwired and checked and showing resistance. What do I do next.
Old 08-02-20, 12:23 PM
Received 940 Votes on 877 Posts
You need to confirm 240vAC to the top of the upper thermostat.
CasualJoe voted this post useful.
Old 08-02-20, 04:36 PM
CasualJoe's Avatar
Received 74 Votes on 65 Posts
And then confirm 240 volts at each element as the thermostats call for heat. When an element shows 240 volts to it, use a snap around amp meter (aka Amprobe) to check for current draw. If no current is being drawn the element is bad.
